Discontinued
Our new flagship router, the CCR1072, is powered by a Tilera 72 core CPU, each core is clocked at 1GHz, and to fully utilize this power, the CCR1072 is equipped with eight independently connected 10G SFP+ ports and single Ethernet port for management purposes.
The unit comes equipped with installed RouterOS L6, 16GB of built in ECC RAM, touchscreen color LCD, two removable (hotplug) power supplies for redundancy, smart card slot, microUSB, regular size USB, microSD and 2x M.2 slots for additional storage.
Thanks to the unique 72 core processor and ports that are directly connected to the CPU, CCR1072 is capable of over 120 million packets per second throughput.
Send purchase questions
Specifications
Details |
Product code |
CCR1072-1G-8S+ |
Architecture |
TILE |
CPU |
TLR4-07280 |
CPU core count |
72 |
CPU nominal frequency |
1 GHz |
Dimensions |
443 x 315 x 44 mm |
RouterOS license |
6 |
Operating System |
RouterOS |
Size of RAM |
16 GB |
Storage size |
128 MB |
Storage type |
NAND |
MTBF |
Approximately 200'000 hours at 25C |
Tested ambient temperature |
-20°C to 60°C |
IPsec hardware acceleration |
Yes |
Suggested price |
$3350.00 |
Powering
Details |
Number of AC inputs |
2 |
AC input range |
100-240 |
Max power consumption |
125 W |
Cooling type |
4 fans |
Ethernet
Details |
10/100/1000 Ethernet ports |
1 |
Fiber
Peripherals
Details |
Memory card type |
microSD, 2x M.2 |
Memory Cards |
3 |
Serial console port |
RJ45 |
Number of USB ports |
2 |
USB Power Reset |
Yes |
USB slot type |
microUSB type AB; USB type A |
Max USB current (A) |
1 |
Smart card slot |
Yes |
Number of M.2 slots |
2 |
Other
Details |
CPU temperature monitor |
Yes |
Current Monitor |
Yes |
PCB temperature monitor |
Yes |
Voltage Monitor |
Yes |
Beeper |
Yes |
Certification & Approvals
Details |
Certification |
CE, EAC, ROHS |
Included parts
SFP compatibility listOpen
PoE-IN compatibility listOpen
RouterOS software manualOpen
High resolution images
Ethernet test results
- All tests are done with Xena Networks specialized test equipment (XenaBay),and done according to RFC2544 (Xena2544)
- Max throughput is determined with 30+ second attempts with 0,1% packet loss tolerance in 64, 512, 1518 byte packet sizes
- Test results show device maximum performance, and are reached using mentioned hardware and software configuration, different configurations most likely will result in lower results
IPsec test results
- Max throughput is determined with 30+ second attempts with 0,1% packet loss tolerance in 64, 512, 1400 byte packet sizes
The device has an operating system preinstalled and licensed. No separate purchase is necessary and the product is ready to use. The device includes free software updates for the life of the product or a minimum of 5 years starting from date of purchase..
Related products
